hermanoW's avatar
hermanoW
2004 Tioga 23e
I have no current to the tv outlet. There is a fuse marked TV and it has 12 volts passing through it. I cannot find the inverter that would convert that to 110. Thanks for any help you can give.
  • Yeah, the GFI's are tricky little devils. Ours stops our kitchen outlet and makes us think the coffee maker is broken!
    We also have a 12V receptacle in our TV cabinet and the outlet there can be turned off by a switch near the antenna booster and night light. More than once we have strung an extension cord instead of remembering that little switch.
  • DUH!!! After scratching my head for two days, I finally found the ground fault reset in the bathroom! Problem solved...
  • Do you have 110v to your outlet when the generator is running or when you are plugged into city electric? A lot of that size NHs don't have inverters standard. Dick
