When you quiet the screen door you may hear other things. The small window in the entry door is held steady by flimsy plastic tabs that break away inside the plastic frame. I sealed the window in place to stop its rattling. You can stop pots and pans and dishes etc. from rattling with that rubberized waffle stuff that comes on a roll. There are large RV rattle wards in mental institutions. Read the thread above where the guy tried to fly his motorhome with the awning up. Have a signal flag on the steering wheel to remind you to lower the TV antenna and disconnect the RV park TV cable. BTW, you may have to shut off power to the TV antenna to get Cable TV signal into your TV. Push button is probably in front TV cabinet. We have a 2004 Tioga 26Q, your rig may be much like ours.
