Big_Katuna
Mar 20, 2014Explorer II
2005 CAT Freightliner check engine light
A while back I posted my CE light had flashed a few times. It was suggested the coolant tank was low. It was. I topped it off and the light never came on again over several trips.
Today it came on and stayed on and the engine went into limp mode.
All guages were normal, no smoke or noises so I proceed to the CG a few miles away.
When I went to back in, I put it in reverse, cut the wheel and when I touched the accelerator, the stop engine light flashed and then both lights went out. I put the slides out and shut it off. Restarted and no lights. All levels checked and normal.
I HAD made a really hard stop at a red light a few minutes before the light came on.
I am wondering if the oil pump sucked some air or some other sensor went dry.
