Gundog's avatar
Gundog
Explorer II
Nov 05, 2018
2005 Expedition 34H replace flooring question?(Pic added)
I have been reading up on flooring projects on here specifically changing carpet to laminate flooring. The problem I see is the driver side slide has a plastic runner on each end of the slide that rides on the carpet it has left a pretty good indentation where it rides on both ends of the slide in the carpet when running the slide in and out. I have my doubts about any flooring products holding up to this. Have any of you changed flooring with a slide like this? The slide is a Power Gear brand. It is a heavy slide.
  • I have been considering several options I do machine work and machine a lot of plastic & aluminum. I am going to try and construct a roller for one and possibly machine a "T" shaped piece of aluminum to go into the floor allowing the flooring to tuck under it but still float. The aluminum is for the roller to ride on rather than on the flooring. I am thinking even if I make a roller it will still leave a mark on the floor where it runs back and forth. I may try the roller idea and if it damages the floor add the aluminum. I don't really want a piece of aluminum in the floor but it may look better than a damaged floor.
    I posted this hoping someone had already solved this issue.
    Thanks Mike
  • A couple of thoughts on that. There is a company that makes a wide nylon(?) slide like skid plate for slideouts, that may be one possibility. Anything wider would spread the weight out a little and help decrease the centralized groove. They make a vinyl cutting board for the kitchen, thin vinyl, and we have used those before to protect rub areas. Just a thought. Hope this may help, Happy trails Bert
