Rgtopda's avatar
Rgtopda
2005 Fleetwood discovery 4 slides
There are four slides to this motorhome and I replaced the passenger side kitchen motor with little effort. however I cannot find the rear slide motor on the passenger side. I looked under the motorhome and I am at at loss as to where I can manually open the rear slide. this slide is not the one on the bed slide ?
  • I am a dummy it is a excursion. it is not the slide where the bed is,,it is the wardrobe slide. I have looked at the manual you posted but it is the opposite side and does not show where the motor is located, it is gear driven. no chain or hydraulic. Sorry I left out so much info. someone stated it was down in the luggage area but did not see it....The other three slides are a piece of cake.
  • Call Fleetwood at 800/322-8216 and ask them. They'll want the FIN number on the just to the rear of the drivers seat.
    Four slides on an 05 Discovery, haven't seen one of those yet.
    Bill
  • Without more info, your post does not give accurate info. Are you positive the slide in question is electric? Is it possible it is a Cable driven(accuslide). Maybe Hydraulic? Bedslides, the motor is usually under the bed base by the outside wall and very difficult to get to. But your post seems to indicate it is NOT the Bedslide? Probably the wardrobe slide? If cable driven, you will see the cables on the outside of the slide wall extended or retracted. Can you post a pic of the bedroom and the slide? Doug
    Is this your system?
    https://www.lci1.com/assets/content/support/manuals/pg_82_S0010_01.pdf
