tropical36
Jun 03, 2019Explorer II
MyBus2017 wrote:
Pulled every fuse checked, switched relays. Still no running or tail lights. Maybe relay in poplocks security system, only other thing that has to do with lights. Any fuse box found other then drivers compartment nothing to do with running lights. Rear rh compartment engine and transmission fuse box. Back to square 1. Security system might be the problem, hope! Thanks for your input.
I'm thinking more and more, that you've lost a ground return.
Open a tail light and use a long wire for going directly to the neg. term. on the chassis batteries.
If you'd like a wiring diagram of such, send me an IM with your email addy.
38,780 PostsLatest Activity: Aug 05, 2026
