- Travelin2ExplorerWe have a 2004 Coachmen 235 and the tank drain is under the fridge. I have to remove 4 screws and remove a wood panel to access it.
LadyRVer is right you can look under the rig and probably see the tubes protruding a bit. Mine are right over the rear axle. The valves are directly above. The water actually hits right on the spring. - LadyRVerExplorer III have had handle valves near the connections under the bed... I have had
a plug underneath a class C, which unscrewed to drain. Did you look under the motorhome?
38,783 PostsLatest Activity: Sep 10, 2026
