enblethen
Jan 29, 2015Nomad
I would investigate the ground connection at the batteries. When I first got my rig there was only one ground connection from both battery systems. I separated the grounds from each battery system and connected to frame with separate bolts.
The converter needs to be checked.
The alternator should charge both systems. The alternator connects to the coach batteries via a charge relay in the battery control center.
38,766 PostsLatest Activity: Jan 10, 2026
