Thanks for the responses.
I believe that the 2006 E450 transmission has a temperature sensor. It is inside and you have to drop the pan and remove the filter to access it. Also the sensor will activate an electric fan in front of the radiator if the transmission oil gets too hot because there are oil cooling coils in front of or built into the radiator. If you can confirm or correct my information please do.
I have a scan gauge and have checked for any codes and there are none. This is probably not as complete a test as a Ford garage can run.
I never had a Check Engine light come on during the course of our trip.
To minimize the problem during the last half of our trip we did not run the airconditioner or defroster. We did not use Tow/Haul and tried to keep the transmission locked in overdrive as much as possible...just let it slow down on the hills but would shift down if we got below 45mph.
I am trying to gather as much information as possible before I schedule an appointment with the local garage (would like to save time and money if possible).
Thanks,
Rolin
