crawford's avatar
crawford
2006 Georgetown slide problem
I just purchased a 2006 georgetown 34 1/2 triple slide the main slide wiggles coming in pretty badly sometime get jammed. Can any body tell me how many hydraulic cylinders it has I find only 1. The center rail rubs hard near end coming out on the lower parts of coaches body. Lipped is the company which made system and not much infor out on this system. It's hard to believe there isn't more then one cylinder doing its job .
    theres two rams on that system and they have about 2.5 inches of free play IF the rams are not ajusted identical you will experience excactly what you describe
    also if it gets low on fluid and you get air in the rams then similar problems
  • I looked all day today while I believe there is another cylinder for the life of me can't seem to find it maybe it's being hid or something is blocking the view of it ?
  • Could you take picture of the front one this is the one I can't find
  • On my 2002 Georgetown the main slide has two hydraulic cylinders. Run the slide out then check carefully again.
