golfknut
Aug 18, 2014Explorer
Turn on a faucet before turning the pump on and see if that makes a difference.
Also, try hooking a short water hose to the water inlet connection and throw the other end into a bucket of water and set your utility center settings to "Antifreeze/Sanitize Lines"(I assume your setting selections are the same as on our rig) and then turn the pump on.
Open a couple faucets inside before turning the pump on. This will pump the water out of the bucket into the water lines in your motorhome.
38,778 PostsLatest Activity: Jun 10, 2026
