- 95impalaExplorerThanks all for the help, I found that the cover had been put on backwards, when I turned it around all good!!
- Rick_JayExplorer III agree with gvisnic and accsys. Before you do anything else, make sure the "chill grill" is closed on the air conditioner itself. There should be a little tab that slides and closes off the airflow through the grate and this will (should!) direct the chilled air to the A/C ducts.
Good Luck,
~Rick - accsysExplorer
gvisnic wrote:
Shut the vents on the A/C unit itself, should re-direct air to the other vents
That's the way our 2006 34N worked. You have to close the vents om the A/C so it will send that air flow through the roof ducts. - gvisnicExplorerShut the vents on the A/C unit itself, should re-direct air to the other vents
- MountainAir05Explorer IIPull a couple vent out, most slip out. Put a light in one facing the other vent that you pull out. Take a small mirror or cell with camera and put up in hole and try to look back to the the light. Do all the vents runs. If it the duct then usually it come loose near the a/c unit output into the duct. Might have to look inside the unit from the top also.
- 95impalaExplorerNot sure if it is ducted or not, there are multiple ducts in the ceiling
- HorsedocExplorer IIa little more info please? Is this a ducted unit or does it blow straight down out of the unit? If ducted, it may be the duct had become disconnected from the unit.
38,766 PostsLatest Activity: Jan 10, 2026
