larry_cad
Jan 17, 2020Explorer II
We all have that problem at some time. Easiest way to fix it is to replace the valve. 4 bolts hold it into place. Remove the bolts and slide the old valve out, and insert the new valve into place. Reinstall the 4 bolts and you are good for another 12 years. Be sure the water tank is empty before you start. About 15 minutes tops.
