cbeierl
Jan 19, 2020Explorer
bigguyracing wrote:
My motorhome has t-handle in a bin with a cable that opens and closes the drain for the fresh water tank. It has always worked perfectly but now when closed it slowly drips water and in a couple of days the tank will be empty! Anyone else have this problem and how to repair it ?
The fresh water drain valve is a cable-operated blade valve as can be seen in the upper right of page 3 of the Plumbing Diagram for your coach. (Note that you can zoom into the diagram and see details much better.) You will also find this valve in the Parts Catalog for your coach, part number 062421-07-000, on pages 251 and 256&257.
You can replace the seals (Valterra Black 1-1/2 Inch T1001-9Vp Bladex Waste Valve Seals-1.5" ), but I've had better luck just replacing the whole valve. Here's an Amazon listing for the valve: Valterra T1001PBC 1-1/2" Valve Body
