- visavis47ExplorerThanks all. Needed the part number because I am not doing the install and don't have a seal in my hand. Gregory J thanks much.
- JRscoobyExplorer II
FIRE UP wrote:
As for the inner one, why don't you just simply remove the hub and wipe things off and see for yourself, what the number is? It will be right there, on the outside of the seal. It could be a "CR" or, Chicago Rawhide brand. But, this way you'll know EXACTLY what the seal part number is and you can cross reference it to your hearts content.
Scott
And while you are there you can read the bearing numbers. Most times, if the seal lasts a week, then starts to leak it is a safe bet you have bearing issue. (If it doesn't last a week? Installer issue) - GREGORYJExplorerYour rear end is likely labeled as a Spicer model # S-130.
The Workhorse seal # is W8000276 and the Dana-Spicer's part # is W20HH100.
https://www.finditparts.com/products/2030547/dana-holding-corporation-
w20hh100
Or made by SKF part# SKF 35000
https://www.rockauto.com/fr/moreinfo.php?pk=1837330&jsn=8
Also see DIY video of replacing seal:
https://www.youtube.com/watch?v=ZNw5wYmektE - FIRE_UPExplorer
visavis47 wrote:
I currently have a leak in the passenger side rear wheel inner seal. All I can find is workhorse part number (way too expensive). Does anyone have the manufactures part number?? Would like to have both outside and inside seal part numbers...Thanks
Unless things have changed dramatically, there will be NO outside axle seal. All that seals the diff fluid from escaping is the end of the hub, is the axle end, with all the bolts tight. About 98% of the diff builders for the larger truck axles, use no actual gasket. They may use Silicone.
Scott - allbrandautoExplorerthe seal will have a part number on it google that number
- rgatijnet1Explorer IIIIt is a truck rear axle and WH used a few different brands. I believe yours may be a Dana rear axle and parts are readily available from truck service shops.
38,777 PostsLatest Activity: May 20, 2026
