Gjac
Apr 15, 2015Explorer III
Check to see if you have had a leak in that area and the wood/foam is soft underneath. This will cause the mirror to vibrate. Coin tap the surrounding area and compare that sound to a known good area the bad area will be more of a thud sound. I found longer lag screws from Lowe's and screwed it into a 1 in thick piece of oak plank that fits between the wall and dash and is hidden.
38,771 PostsLatest Activity: Apr 15, 2026
