Mr__Steve
Jan 30, 2018Explorer
2008 F-53 Chassis
Any ideas on reason for my motorhome to pull to left when I brake. I have new tires, had front end aligned, new brake pads. Thanks!
10forty2 wrote:
Tire pressure, bad tire, a dragging brake, out of alignment....all will cause a constant pull to the offending side. If it only happens when you brake, then it tends to reason that the brakes on the pulling side is grabbing harder than the other side. That may mean that the caliper on the opposite is NOT grabbing at all, or is not grabbing as hard. Why? stuck caliper is my first guess. If you serviced the brakes and didn't service the calipers by cleaning/greasing the guide pins, then they may be sticking instead of moving the pads towards the rotor. The pads themselves (on the opposite side of the pull) could have a glaze on them if they weren't broken in properly after installation and even though they are compressed against the rotor, they may not be grabbing it. And like said above, the hydraulic line on the opposite side of the pull may be collapsing or have trash in the line blocking it from transmitting the pressure to the caliper. Where could the trash come from? Maybe from the inside of the line deteriorating...maybe from contaminated fluid... Best bet is to pull the brakes again and check things out.
