PFGuil49 wrote:
Check the Entry Door Switch fuse (7.5 amp) and the Entry Door Sensor fuse (7.5 amp) located in the outside panel under the driver’s seat. The Entry Door Switch fuse is for the on/off switch on the dash/panel and the Entry Door Sensor fuse controls the steps when the ignition is turned on. Also, when you replace the magnets, were they like for like. My old ones was white with a ¾ inch bore so Coach Step advised me to replace them with the same color and bore magnets. I also had to replace my Entry Step Module because the old one shorted out and burned up. I installed module #301702, replaced both magnets (one in entry door and other in door frame), and all 3 fuses, step motor fuse (20 amp), Entry Door Switch fuse (7.5 amp) and Entry Door Sensor fuse (7.5 amp). Coach Step Technical Support was awesome. If this doesn't fix it, give them a call at 574-537-8900
Thank you for the information. My problem is I don't have anything telling me which fuse goes to what other then the Monaco Operators Manual which has some fuses labeled but not all. There were a couple that labeled fuses as step. I checked them and they were good. I guess I'll just have to check every fuse in the box
