monacorw's avatar
monacorw
2008 Monaco Entry Step
I have a 2008 Monaco Camelot with a Coach step and control module #301702. I replaced the magnetic switch for the door and now the step is not functioning properly. It still extends/retracts when door is open/shut. However, now it will not stay out when parked and the door is closed. It also will not retract with the ignition key is turned on. HELP!!!!
  • PFGuil49 wrote:
    when you replace the magnets, were they like for like. My old ones was white with a ¾ inch bore so Coach Step advised me to replace them with the same color and bore magnets.
    One color of proximity switch is closed when near the magnet, the other color is open when near the magnet. Kwikee Step Magnet
  • Check the Entry Door Switch fuse (7.5 amp) and the Entry Door Sensor fuse (7.5 amp) located in the outside panel under the driver’s seat. The Entry Door Switch fuse is for the on/off switch on the dash/panel and the Entry Door Sensor fuse controls the steps when the ignition is turned on. Also, when you replace the magnets, were they like for like. My old ones was white with a ¾ inch bore so Coach Step advised me to replace them with the same color and bore magnets. I also had to replace my Entry Step Module because the old one shorted out and burned up. I installed module #301702, replaced both magnets (one in entry door and other in door frame), and all 3 fuses, step motor fuse (20 amp), Entry Door Switch fuse (7.5 amp) and Entry Door Sensor fuse (7.5 amp). Coach Step Technical Support was awesome. If this doesn't fix it, give them a call at 574-537-8900
