EMaznio
Oct 06, 2013Explorer
Monaco Keyless Entry Pad Code
Just in case someone reading has been unable to locate the keyless entry pad code on their Monaco (possibly other RV's also), I thought I'd share my findings. I called Monaco and they suggested I look inside the locked compartment in front of the driver's side front tire. In the upper right hand corner, there is a white box with a label on the outside (some reference to Ford security system). There is a large printed 5 digit code on the label that is the code to unlock the coach. The standard code to lock the coach is to press the furthest two right pad buttons (7/8 and 9/0) simultaneously. I hope this helps someone out there in RV.net land.
