j-d wrote:
Rental outfits seem to make little tweaks in the build orders for their coaches. Specifying a BIRD would help make the units a little more Renter-Proof (if that's really possible) by helping keep both batteries up while the renter is on a hookup site.
It'll be interesting to see if retail Fleetwood units are equipped the same. Would be nice if they are...
Yes they are,I have encountered several retail Tiogas that were equipped with a BIRD when I was looking for mine. The cheaper Jamboree models of the same year did not have them.
As for the tire valve extenders The best on the market,that are the original,are
Tire Man.
Chuck is the original designer of these an he has been around for years. If you have any questions just give him a call, he is always happy to help. Any others are just cheap reproductions of the original.
The kit looks like
This it is for all 6 wheels,they also come with flow-thru valve caps so you don't even need to take then off to check the pressure.
Here is a list of all the products he sells.
They make checking tire pressures fast and very easy.
