jwlong's avatar
jwlong
2008 winnebago access slide not working??
Hi all,
Just recently purchased 2008 Winnebago access bunk house. Living room slide worked fine over the weekend camping and now will not work. The red parking brake light on the switch panel flashes but the parking brake is set. The rear slide works no problem. Any ideas and suggestions would be greatly appreciated!
  • Thank you. I guess its time to start chasing wires. I tried switching out controllers and its the same deal so I have ruled that out.
  • The manual for my 07 Winnebago says to keep the engine running while putting out the slide for the added power the alternator provides. I doubt that Winnebago has changed that.
    Also, note that the second slide he mentions works.
    To the OP, since the second slide works, it isn't in the parking brake or its switch. It must be in the wiring bringing the parking brake signal to the first slide. That is where I would look.
