j-d
Aug 29, 2018Explorer II
Caster is important. Your numbers are in the middle of the range that goes to 7*+. Chassis is built with 0.5*+ more caster on passenger side. I'm working on ours now and hopefully can get at least 5.5*+ left which would be 6.0*+ right. Camber near Zero both sides AND Toe slightly IN.
Harvard has schooled himself in this and should be around shortly.
I close with a caution. Get your ride height the way you want it before having it aligneed! Load, tire pressure,air bag pressure, etc.
38,782 PostsLatest Activity: Sep 10, 2026
