Harvard
Aug 29, 2018Explorer
Wandering at Highway Speeds
Reply Post by 2kGeorgieBoy says it best....
Re: Wandering at highway speeds
Reply #36 on: March 14, 2018, 09:07:02 PM
START QUOTE:
Jeff..Although we have a 2000 Georgie Boy 31' Maverick "C" on a Ford E450 chassis, I can fully agree on the caster effects, at least for us. When we got the unit in Jan 2014, the dealer had us take into a truck shop for an alignment. It turned out OK....A trip to Moab shortly there after brought out the problems. I then started reading the threads and comments here about the caster settings....esp., from Harvard. I checked the data from the first alignment and found that it was set at about 3 1/2 degrees positive...about in the middle of Ford's recommended range. Shortly before a cross country trip to Maryland in fall of 2016, I returned to the shop where the first alignment was done. I talked to the service manager and he knew of the problems with the E450's and was happy to increase the caster as I asked. The alignment tech was also familiar with it and ended up with settings close to 5.5 degrees positive. WHAT A DIFFERENCE! The unit tracked straight down the road, passing semis no longer caused a white knuckle hold on the wheel, and overall it was just a lot more enjoyable. It did however increase steering effort a little but not anything to worry about. But, be sure that the shop you go to is willing to "think outside of the box". Our first alignment was "plain vanilla", right in the middle like it was always done. Second time out, they were very willing to increase settings beyond what normally would be done, and still stay with in Ford's guidelines (0-7 degrees, I believe). I realize that our E450 chassis is an entirely different animal than yours, but I was trying to add support to the caster increase thinking and how it helped us......if you go down that road.
END QUOTE:
ruffingit is another happy camper
ruffingit QUOTE:
I know this is a old thread and I'm a new member but when I recently bought my 2017 Thor Freedom Elite class C, I had a white knuckle ride home from where I bought it in Arizona back to California. The drive was very disappointing, when I returned home I sent Ford a letter about my experience and they actually called me. I was informed that Ford gives each new RV chassis a generic alignment as it rolls off the assembly and stated the RV manufacturer who adds the coach to the chassis should give each unit an alignment, even he admitted that it is rarely done. He suggested that I contact "Thor" of course Thor informed me that they do not do alignments on their new coaches and it is not covered under the purchase of the coach. So if you buy a new coach make sure you get a wheel alignment, it runs a couple hundred dollars. That, and a couple of suspension upgrades eliminated the problem. Hope this helps.
END QUOTE.
START QUOTE:
END QUOTE:
ruffingit QUOTE:
END QUOTE.
38,782 PostsLatest Activity: Aug 23, 2026
