theoldwizard1
Aug 29, 2018Explorer II
donn0128 wrote:
Find a good alignment shop that knows how to fix Fords wondering problems. This has been a major Ford problem since the early 80s, so a good mechanic should understand how to fix it.
Concur ! Find a shop that specializes in alignment and tell them your issue.
I agree with the other comments about caster. This is a "non tire wear" adjustment and pushing it to the end of the positive limit will help a lot.
I would also fill your fresh, gray and black tanks to about 1/2 full. Also, if you carry anything heavy in the back or attached to the bumper include that ! You want the unit to be as close to average driving weight as possible.
38,782 PostsLatest Activity: Aug 23, 2026
