The_Nomad1's avatar
The_Nomad1
2009 Forest River Georgetown 35 - STEPS
Hello,
As the title indicates, I am having issue with the Lippert steps on the referenced unit. They are the three step variety and I have attempted to follow the troubleshooting instructions to troubleshoot with no luck. The problem is that they will not function at all. They will neither extend nor retract unless directly energized. I would appreciate anyone else's insight on this to help me figure out what to replace.
The first test was RED wire on the chassis side plug for hot with "switch" on and off. Both instances showed 13.7V which the manual indicated was "replace switch". I replaced the switch with no change in condition. I attempted to proceed through the indicated tests, though some were not possible (as I understood the instructions). I can extend and retract the steps though with direct connection. The steps function appropriately in this condition. I just don't know how to sort out what is happening in between.
Some of the wire colors are just not there and some of the component in between, I just don't know how to test correctly.
I appreciate anyone's help in advance.
JMM
I know this is vague. I can provide as much more information as I have, but just don't know what is relevant with these systems.
  • Thanks for the replies. It ended up being the magnetic door switch. The troubleshooting guide that came with it had the switch signals reversed which had me confused. All is good now. Again, thank you.
  • Older LCI Coach steps(yours) had a problem with the step control module getting corroded. Odds are, you module is corroded up internally. Good news is, LCI fixed that problem 5 or 6 years ago and the new modules are completely sealed now. So, replace the module. Doug
  • Yes, the 25AMP fuse is still good. My diagrams indicate a 6 amp fuse dedicated to the switch that I have not managed to find.
