dave_330's avatar
dave_330
2009 Monaco Knight Elect. step problem
It started with a broken green ground wire, I repaired that now it won't work at all. I checked the fuses all ok. I killed power to both the motor and brain box, nothing.
  • Dave, very carefully check the connection under the steps. These sometimes pull loose and get corroded causing the power issue. I just replaced my step motor and cleaned all these connections up.
