SC_Outdoors
Sep 09, 2016Explorer
2010 Fleetwood Discovery 40G Battery Connnections
Hi,
Having some electrical issues and think that it may be due to the 6V battery connnection. Can someone who has a 2010 Fleetwood Discovery 40G post or e-mail a pic of your 6V battery compartment and terminal connections?
Either the four 6 volt batteries are connected in correctly or the inverter has a problem.
I tried to start the engine and the two 12 volt start batteries were dead. Tested both starter batteries, they read 10.7 amps. Hooked up my charger, hit the start assist button, and the engine started. I went ahead and replaced the batteries, reconnected everything and now the inverter display reads HI DC 19.4
I also noticed that now the microwave display was not on and the 120v outlets are not working. Checked the breaker box and nothing thrown. Also checked fuses and all good there. Checked the GFI plugs and could not find one that popped?
The next step is taking it to the Dealer @ $140 per hour labor rate.
