denk's avatar
denk
2010 Winnabago Aspect 30C rear overhang
I'm thinking of purchasing a 2010 Aspect 30C on a E450 chassis and am figuring out if will back into my driveway, I have a steep incline with a small bump.
Does anyone have the dimensions of the rear wheel centerline to the rear of coach and the height of the coach at the hitch?
1 Reply
  • I have a 2012 28ft I think it is and there is very little clearance with it. I can easily rub going over small bumps. I tried to hang a hose carrier and it was about torn off and this was not far behind the wheels. I would guess the 30 ft would be the same or worse.
    I guess you could build a ramp to help get in out of the drive, I have seen tht recommendation a couple of times.
