- randywhite30ExplorerIts a plugin, just like the picture.
- j-dExplorer IIGOOD!
But we all want to know... IS there a Transfer Switch? Or do you have to plug like pictured above? - randywhite30ExplorerLooks like it was just the breaker. Thanks everyone.
- IAMICHABODExplorer III
- Horizon170Explorer
Mich F wrote:
Are you positive you have an automatic transfer switch ? I just saw a brochure for the 2014 Coachmen Freelanders and they are manual generator changeover, meaning you have to plug your shore power cord into an outlet, in your RV, to get power from your generator.
Right on-----maybe. My 2010 Freelander didn't come with a Xfer switch. I installed one this morning. - Mich_FExplorerAre you positive you have an automatic transfer switch ? I just saw a brochure for the 2014 Coachmen Freelanders and they are manual generator changeover, meaning you have to plug your shore power cord into an outlet, in your RV, to get power from your generator.
- randywhite30ExplorerI did check the breakers. I will look again tonight.
- DrewEExplorer IIIOn my '98 Coachmen the transfer switch is mounted onto the back of the AC side of the power center. That's a common, but by no means universal, mounting location.
Have you verified that the circuit breaker on the generator itself is not tripped by manually resetting it? Sometimes they can be tripped without obviously appearing to be tripped. - randywhite30ExplorerThe issue seems to be fairly simple.
The generator powers on and is producing power, but that power is not getting inside the cab. - bdpreeceExplorer IIFollow your power cord back into your rig. The box it enters is most probably your power transfer switch. When you find the box have someone turn the power off then on the box should make an audible click or thump sound. With power disconnected remove the cover and visually inspect for melted wires. Tighten all connections. This is a maintenance item that really should be done once a year anyway.
Having your AC on when switching from shore to generator is not recommended but in most cases would only blow the breaker on the generator or in the power panel.
38,782 PostsLatest Activity: Aug 31, 2026
