lordnorth
Apr 19, 2015Explorer
LennyH wrote:
Hi Chris
The holding tank for fresh water is located above the third bay door on the right side on the RV, after you open the bay door you have to remove the panel on the top of the compartment and there you will see the holding tank, Hope this helps.
Lenny
Thanks Lenny. I will take a look tomorrow to see if I can find it. You don't have any suggestions on how to get to the holding and grey tanks to you? I am less concerned about these since PURE water freezes at 32... so these should freeze considerably lower, but I'd like to find out for sure what the temps are there.
rcmiller32 wrote:
Not sure on your model, but on our 2014 Coachmen Pursuit the black tank sits right under the toilet and the gray tank runs crossways behind the black tank. The wet bay has the furnace line blowing in to warm the compartment. They took the 4" line and put a tee into it. Then there is a 2" line ducted down into the compartment.
You might have to remove or move the panel in that compartment to see were the tanks are. At the least to follow the piping.
Thanks... but I'm not sure which compartment you are referring to. My wet bay doesn't stay warm at all. With the furnace running it was warmer than ambient, but still below freezing. I figure mine must be below the toilet as well, but can't figure out for the life of me how to get to it.
Chris
38,780 PostsLatest Activity: Jul 04, 2015
