MrWizard wrote:
why is at the dealer for sale ?
did the OP trade it in after the replacing the engine ?
why was it repainted ?
These are very good questions that need a logical answer. They should make sense to you. You should look under the front end to make sure that everything was buttoned-up after the engine change, and to look over everything underneath. Even if you do not know about the underside, look for loose things, scrapes, or broken things, or things that do not look right. Same thing on the inside, be very critical, open everything, feel for solidness where there should be solid. Pull on things, make sure that everything does work, do not take their word for it. They are really proud of the unit, it seems from the price.
To me, there are some red flags on this unit, that's just to me.
