GollyCollie
Jan 15, 2014Explorer
Ahhh, got it. That's what my wife said too but I wouldn't believe her. :) If water got to there then I can tell you what happened. The front cap filled with water, and once it was full it seeped into the bunk/deck, which is hollow. That water ran backward until it reached the rear of the bunk/deck where it seeped through the screw holes where the screws attach the driver transition attaches to it. That is my bet. I would pull that vinyl trim off of the front of the bunk/deck and inspect the inside of the cap. If there is no insulation in there, that mean he has had water in there that someone has cleaned up. The bunk/deck is probably water damaged also. Uhhhh. I wonder how many of these are out there?
