crisset22's avatar
crisset22
2013 Roadtrek RS air conditioning problem
I have a 2013 Roadtrek RS on the MB Sprinter with a 11,000 BTU Dometic Penquin air conditioner. The AC does not seem to be sufficent to cool the van. When it is over 90 out, I can only get the temp down to 81 with the unit on high. I have had it looked at once, and they found no problems. I have closed the shades, put a relector in the windshield, and it is still not cool enough. I am getting very frustrated, as it is just not comfortable in the RV when parked (Mercedes dash air is terrific). It also makes no difference if I am plugged in or running the AC on the generator. I wonder if anyone else has had a simialr expericne with their Roadtrek and did you solve the problem? Also, do others have no problems cooling their RVs? I am considering getting a second option from another repair place. Roadtrek said I can't put a bigger AC unit in becasue the 2.5 kW generator will not handle it. I would really apprecite any suggestions. I live in CA so if you are not on the coast in the Summer, it is likely over 90. Thanks for any replies and suggestions.
  • This cooling problem in Bs doesn't sound promising. Do they have less insulation in the ceiling than TTs and TCs, then?
  • It depends on if you have been driving the van or if its been sitting. If driving, it gets very hot, it is a big metal can, so it takes quite awhile for the van to cool down. 10 degrees is probably about as good as you can do at that point. It will help if you can park in the shade, hose down underneath of the chassis, and open the hood. 15 to 20 degrees below the ambient temp is probably about the best you will get under ideal conditions.
    I couldn't even use my Rt here in AZ in the summer, had to seek cooler climates.
    I doubt there is anything wrong with the A/C.
    The Reflectix that was referenced does help.
  • I've wondered about buying some Reflectix, gluing it to a hinged Coroplast back, and cutting to shape some sun reflectors for the windshield and other windows. It can wedge into place, or perhaps pieces of Velcro could help in other spots.
    11kbtu should be doing a good job cooling the "B". I'd have the A/C checked out while it is still under warranty.
  • Our solution to the problem you describe is a combination of several things.
    We have an '08 PW Lexor - so a Chevrolet chassis.
    First, if it's HOT outside, whenever I can, I park in the shade - even if it means a bit of a walk.
    Second, while our "dash" A/C will carry the load while we're driving - we do know that the rear is not as comfortable as the front - but, we travel in the two front seats.
    So, before we arrive at our destination, we pull over, start the genset and turn on the roof A/C - so now two A/Cs are running. It gives the roof A/C a bit of a "head start" on the "house".
    Third, and I'll admit that I "pinched" this idea from another forum poster - MyRoadtrek - though I made my own modifications to his suggestion.
    I went to Lowes (Home Depot didn't have it then, but does now) and bought a roll of Reflectix. It's a bubble wrap with an aluminized foil on both sides.
    Next, I cut out pieces for the inside of every window - every one.
    That wasn't enough when it got to be 95 plus or so. So, I cut out some more pieces to cover the outside of every window.
    The inside pieces simply "fit" in the opening and they do stay put. the outside ones are "temporarily" attached with some "blue painters tape", but we only use them when we're parked.
    When both are installed, it's cool as a cucumber inside.
    I think the secret is keeping the glass cool.
    When it's hot as the dickens and we're driving, we leave all the "inside" ones installed, removing only the driver and passenger windows and the windshield.
    Yes, it's a bit dark inside, but, it's comfy.
    When we're at a campsite, and it's hot as the dickens, I install only the ones on the "sun side", so we do have some light.
    DW thought I was nuts when I made 'em. Can't leave home without 'em now - if it's gonna be HOT.
    Sadly, MyRoadtrek's website is now history. He had some great photos of his solution. He lives in Tucson, AZ, so I know he understands HOT.
    Cheers.
  • I have a conversion van. Little Colman heater/AC. Same problem when in direct sunlight. Last summer we just threw a plastic tarp with shiny aluminum side out over the area in direct sun. Outside temp 100, inside 92 dropped to 78. This year I bought little LG portable AC with hose pointed out window. Works with higher amp outlets, wouldnt try it on typical house circuit. Didnt break out generator for this. If you have plug in electrical and generator, this would work fine. I am kinda surprised brand new RT wouldnt cool better. Are you sure of your settings? Have you tested or had the AC tested by dealer?
