dougrainer
Mar 07, 2023Nomad
MOTOR HOME FUSES AND
CIRCUIT BREAKERS
The 120-volt circuit breakers and 12-volt fuses
are located on three separate panels. The purpose of these three panels is to provide electrical
circuit breakers and fuses to interrupt current
flow if a circuit is overloaded.
1. 120-volt House Electrical — This electrical panel is located under the bed or the
refrigerator (location varies depending
upon model). This panel is very similar to a
residential panel with resettable breakers.
2. Fleetwood Automotive 12-volt System —
This panel is located in a side compartment
or in the engine access compartment. This
electrical center contains battery disconnect
systems, entry step, fog light, and some other
automotive circuitry.
3. 12-volt Chassis Fuses — This electrical
panel is located under the driver’s side
dash area
CIRCUIT BREAKERS
dash area
38,782 PostsLatest Activity: Sep 10, 2026
