dougrainer
Mar 09, 2023Nomad
PCronin68 wrote:dougrainer wrote:
MOTOR HOME FUSES AND
CIRCUIT BREAKERS
The 120-volt circuit breakers and 12-volt fuses
are located on three separate panels. The purpose of these three panels is to provide electrical
circuit breakers and fuses to interrupt current
flow if a circuit is overloaded.
1. 120-volt House Electrical — This electrical panel is located under the bed or the
refrigerator (location varies depending
upon model). This panel is very similar to a
residential panel with resettable breakers.
2. Fleetwood Automotive 12-volt System —
This panel is located in a side compartment
or in the engine access compartment. This
electrical center contains battery disconnect
systems, entry step, fog light, and some other
automotive circuitry.
3. 12-volt Chassis Fuses — This electrical
panel is located under the driver’s side
dash area
Fleetwood customer service says there is not one fuse for each slide out. They are controlled by one module located in engine compartment.
I have worked on all brand Motorhomes for 43 years and have NEVER, seen a slide module or fuse in the engine compartment. NEVER. Remember, you have a 2014. Odds are the people you talked to at Fleetwood have never seen or worked on your RV as they have not been with Fleetwood very long. ALWAYS ask when you call OEM's technical, how long they have been employed by that maker. Doug
38,782 PostsLatest Activity: Sep 10, 2026
