- willaldExplorer IIThe filler tube on V10s in Motorhomes, I believe in most cases is pretty long and has a turn or two in it. is it possible, the cap is still stuck in the filler tube, and didn't make it down to the engine?
Ify ou can confirm somehow using the methods already suggested that the cap is in the filler tube, and you can't pull it out with a grabber tool of some kind....Then I'd just pull the filler tube off, then you should be able to push the cap out.
If its not in the filler tube and is already down in the cylinder.....Then like already said, you need to go ahead and pop the cylinder cover off and try to get it out before it does serious damage.
Oh, and like already said.....Running the engine now, before you get that cap out, would be a very, very BAD idea! bgum wrote:
When I was a teenager I worked at a full service gas station and a guy came in with a new car he had just won at a school raffle. He had dropped a plastic cap in the radiator and had been fishing for it for a couple hours. I was able to catch it after about 10 minutes.
I would suggest letting the motor idle and look in the hole to see if it will float by.
The cap was dropped down the oil fill tube, not the radiator. Running the engine would be a terrible idea!- valhalla360Navigator
waterboy502000 wrote:
It's the 362 HP version.
Good thing it's the 362 HP version. They thrive on misc plastic bits ;)
But seriously, flash light and/or scope and something long to snag it out.
If that doesn't work, it looks like you are popping the valve cover off.
Update: Did it go in thru the cap in the valve cover? The tube for the dip stick normally wouldn't be big enough for the cap to go thru.
Also, don't run the engine hoping to find it. It might just bounce around on the valve train or it might get chewed up until little pieces block something and part of the engine stops getting oil. - bgumExplorerWhen I was a teenager I worked at a full service gas station and a guy came in with a new car he had just won at a school raffle. He had dropped a plastic cap in the radiator and had been fishing for it for a couple hours. I was able to catch it after about 10 minutes.
I would suggest letting the motor idle and look in the hole to see if it will float by. - RedRollingRoadbExplorerA low cost borescope to help spot it? I got a $30 one of Amazon helped the grandson find a cell phone that was well hidden in the motorhome. https://amazon.com/gp/product/B07C9C6P5D/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
- MountainAir05Explorer IIIf you can see it a mechanic fingers and hopefully you can snag it out. I have found many thing in the valley over the years.
38,756 PostsLatest Activity: Oct 21, 2025
