Bumpyroad wrote:
its possible your unit has neither. I mean the bypass is usually/always near the water heater and that should be accessible.
bumpy
Doubtful. the XL series of Georgetowns have pretty much all the extra 'bells and whistles'. I'd be VERY surprised if they skimped on something as simple as a water heater bypass or low point drains.
Look all around your water heater, follow out the water lines going into it as far as you can. There should be a bypass line between the two lines at some point, with a couple valves around it. Owner's manual may or may not be any help, they don't always have information that specific in there.
As to the low point drains: On our 2012 Georgetown, the low point drains are just below where the water pump and water tank are located. If you don't find them there, I would crawl under it (there is surprisingly a lot of room under these things to move around, once you get down there), and have a good look around. Look along the sides close to the edge, thats where the drains will probably be. You're looking for two hoses/pipes dropping down, with caps on the end you can take loose to drain things out.
