willald wrote:
As to the low point drains: On our 2012 Georgetown, the low point drains are just below where the water pump and water tank are located. If you don't find them there, I would crawl under it (there is surprisingly a lot of room under these things to move around, once you get down there), and have a good look around. Look along the sides close to the edge, thats where the drains will probably be. You're looking for two hoses/pipes dropping down, with caps on the end you can take loose to drain things out.
on my TT one is white and the other is red.
bumpy
