Sorry but reading this sounds like you would nitpick a Newell . Most of these are so minor to be considered nominal. The antenna light location? Come on. The steering and handling likely addressed with proper psi and sway bar adjustment. Did you drive it before you bought it? I have no such issues with my doghouse latch so I am thinking it needs nudged. Very normal. We love our 29.2. But then again with the exception of what I would consider an actual issue like the septic line, I just deal with adjustments. Most people do. The bunk has a built in step system, that's what the small piece of counter is behind the driver seat. An no one builds a gate or net for the front of the bunk. That's not an issue. Can't read the instrument panel ? Seriously ? That's the same panel on every new rv on the road. As far as road noise etc, well you bought an entry level coach. Again did you drive it before you bought it? Most of that likely due to improper psi . Weigh it and adjust accordingly. I have no qualms with the water pump. You will not get home pressure from an rv. The fan under the bed is the inverter and should only run hard if you are running a lot of 12v. That means it's working. Where would you like them to put the furnace. I would agree on one thing, the outdoor shower location is silly.
