enblethen
Dec 13, 2018Nomad
Check the voltage on your battery disconnect. The two large posts are the 12 volt battery connection. One should have battery voltage, the other side with shore power disconnected should have zero volts if battery disconnect is off, with battery disconnect on it should have battery voltage. With shore power connected and the converter is working properly the coach side of disconnect should have 13+ volts from converter.
No voltage from battery would indicate bad connection either on positive or negative, or there is a hidden fuse or circuit breaker between battery and disconnect.
