enblethen
Dec 14, 2018Nomad
Inverters use a much larger 12 volt DC wiring and fusing then a converter.
Between the battery and the converter, near the battery, you would be looking for a small 12 volt DC circuit breaker. A small unit, about an inch square with two studs. I would guess that it would have a rating of less then 50 amps.
Follow the positive cable from coach battery toward the battery disconnect.
38,782 PostsLatest Activity: Aug 11, 2021
