enblethen
Dec 18, 2018Nomad
You should be looking for a larger fuse/circuit breaker. Somewhere around a 50 amp.
5 amp fuses could be for step or LP detector
Did you check around battery disconnect for fuse/circuit breaker?
Verify that the negative battery cables are connected to frame. It could be that there is more then one and someone dropped one.
Have you reset the 120 volt circuit breakers? Turn them to off applying light pressure toward off. Then turn main on followed by branch breakers.
38,782 PostsLatest Activity: Aug 11, 2021
