jstrong499's avatar
jstrong499
2015 Coachman Lepracan coach battery?
On our last camping trip the coach twin 12 volt deep cycle batteries just died. I installed 2 new ones today but no power, lights or reading of the moniter guaves. I cranked the Motor, then the generator cranked, and all work just fine, I turned the ignition off, no problem, cut the generator off and lights all died, no voltage anywhere
Sounds like a breaker or fuse somewhere.
Any ideas???
Jamie in Alabamag
  • When you started the engine, the house was operating off the starting battery, once genset was running, the converter took over.
  • Drems strange that when i cranked the coach up that the batteries came online, or seemd to, because the generator spun like they normally would with good batteries?
  • Sounds like battery disconnect is not on. Cycle system to off then back on.
    Next would be a fuse adjacent to the coach batteries.
    Battery fuse in the 12 volt DC panel
  • That happened at work to a new kid just out of tradeschool. He left the plastic cap on the positive post of the battery when he attached the cable.
  • Breakers are the first to check. Then fuses and then clean, strong battery connections.
