Cbones
Apr 27, 2015Explorer
Mr.Mark wrote:
I'm going to throw this out...
Check to see if you have tripped one of the GFI outlets in the bathroom or maybe in one of the under bays. It might be as simple as that. Also, aren't there two breakers on the inverter itself? Double check the inverter to make sure everything is OK.
Good luck,
MM.
There is only one breaker on the inverter, it is a push to reset, already checked. The gfci circuit is working when the genny or shore power is on, just not when inverter only.
38,782 PostsLatest Activity: Aug 30, 2026
