Cbones's avatar
Cbones
2015 Thor Challenger Residential Refer
A friend of mine purchased a 2015 Thor Challenger. It comes standard with a Residential refer and a Xantrex 1800w inverter running off 2 6v deep cycle batteries, as well as a rudimentary Magnum Autogen start. The problem is that the refer will only run if connected to shore power or running the genny. Does this make any sense, or is this a wiring issue? Would an 1800w inverter be large enough to handle the refer load? The inverter is definitely working, as he can watch tv and power the sat receiver off the batteries, however, we were unable to find any hot outlets when only in inverter operation. We were boondocking this past weekend, and he had to run the genny continuously, which kind of defeats the purpose of having quiet time. Unfortunately, I have very little experience with the late model gas coaches.
  • Executive wrote:
    My guess is there are TWO outlets BEHIND the fridge. One operates on A/C only and the other is tied into the inverter. The fridge is plugged into the WRONG receptacle. Look behind the fridge and plug the reefer into the OTHER plug....Dennis
    6 volt batteries, I thought they were all 12 volt batteries. Am I wrong? Never have had a prob with my fridge yet. I best see if I have any resets (gfi or whatever) just in case. I still haven't been able to find my on/off switch for the outside exterior small fridge, lol. So I don't know if it works or not.
    Doesn't take much of an inverter to run a fridge of any sort, but adding a couple more 6v golf cart batteries (connected in series for 12v) would sure help on longevity. If you can't find an inverter outlet back there and when all else fails, find a convenient inverter circuit to tap off of and run to an outlet behind the fridge. Not much to that and I did so in a campground with an overnight stop one time, when our RV fridge refused to stay on gas. Once I got back home, I made up a auto relay circuit for switching back and forth on it's own, so no more on gas when going down the road and without even having to think about it.
    Well, you're wrong and you're right. You do need 12vdc with however you might be able to get it, but the preferred and most efficient method is for having two 6v batteries connected in series for a total of 12vdc. For those having more batteries, then these banks of 6v are in turn connected in parallel. This keeps the voltage at 12, but doubles the capacity. True deep cycle or golf cart batteries are also preferred and not the common 12v marine type that you find quite often.
  • you said certain outlets were inactive on the inverter..check to make sure one of the inverter circuits is not tripped..that would do it as well... So GFI check, inverter check, outlet check to make sure you are plugged into right outlet....
  • Some coaches do not have all the outlets hooked up to inverter use. They only have a couple. But one of them should be the refrigerator outlet. Maybe Thor figures this coach should only be plugged into shore power in order for the refrigerator to work. Two house batteries is just not enough to run everything in the coach unless you have solar panels. I have seen coaches with four six volt batteries and a 2000 watt inverter have problems keeping the batteries up while dry camping. Generator has to start every eight hours.
  • Oops, yes do have two 6v batteries hooked up in a series for power of 12 volts. But why couldn't I just run or replace them with one 12v battery or even 2. I'm not technical savvy at all.
