dougrainer
Mar 24, 2021Nomad
You extend the step cover and remove the mount screws to the motor track assbly. Doug
If the step cover is stuck retracted, you have to use brute strength to pull it out OR remove those 3 bolts on the backside by the genset to allow you to pull the cover out. If it destroys the motor, who cares. You are replacing it anyway.
