Chum_lee
Jul 12, 2018Explorer
Desert Captain wrote:DownTheAvenue wrote:
First thought is to check air pressure on the tires after weighing the rig ideally one wheel at a time. Air pressure should be adjusted accroding to the weight carried.
X2 Sounds like your tires are seriously overinflated for the load they carry. The original shocks on a 2018 should be fine.
:C
X3! Don't make it more complex than it is. Are you running 19.5" Goodyear G670's? (I do.) I start at 80 psi and work up. Usually I run at +-90 psi cold all around. Lower pressures tend to wear the front outside edges of the tires. Over 90 psi creates the symptoms you describe.
Chum lee
