Gjac
Jul 18, 2018Explorer III
These rough ride issues are hard to diagnose because they are very subjective to the driver. Is this your first Class A? I see it is a 2018 so I assume it is new to you. They will always drive like a big truck at best never like a car or DP. Before you spend a ton of money with add on's to improve the ride give your self a chance to drive it and get comfortable with it. When I first bought mine 14 years ago it was a white knuckle ride all the way home. After several long trips and several thousand miles later I drive it with one had like a car even when passed by trucks. After you get comfortable driving it adjust the air pressure based on the weight, try to re position the stuff inside so each tire carries the same weight and is balanced then do the CHF if needed. What is the length of the MH and wheel base of the MH?
