wolfe10 wrote:
"Not much change in power...."
Maybe, maybe not.
A quick look at the specs for the new V8 shows both peak torque and peak HP at 3,900.
Don't have RPM's for V10 at my finger tips but if at significantly higher RPM, I will take the "RPM I can sustain all day long" over specs at "screaming high RPM".
Anyone have specs with RPM for the 2006-2015 V10 engines?
With the 5 Star Tuning my max HP and Torque is at lower RPM's over the stock tune, I think its in the 3600 to 4000 rpm range.
The reason the V-10 scream in high RPM's was the 5 speed factory tune cause the trans to down shift to 2nd gear in the mountains, with the 5 Star Tuning it goes from 5th to 4th than 3rd and holds, no more screaming RPM's..
2008 F-53 V-10
